OBDII Port/Scanner Prob
VCO
Has anyone tried to plug an OBD2 scanner to a Disco 1 ?
I tried but it did not work with my Disco . I don't know if its my scanner or the port or Disco 1s OBD2 compatibility
has anyone tried ?
I suggest you Change the car and try it if it works if yes keep the new car LOL!!!
Sounds good :D
I think its not for GM only
in fact all the cars sold in US from 94 onwards should have OBD2 as a standard
I have read that V8 3.9 99 00 Disco 2 's support OBD. its limited but still supports you can see the temp of engine coolant, gearbox and some other info from ECU and reset some basic things
but I do not have definitive answer for Disco 1
lets try on other cars and see what happens
Discovery 1 is OBDII compliant, but you need a different adapter to plug the diagnostic system. X Launch 321 has all LR related adapter in the case, so get the check from guys who check LR with X Launch. I got same checked in my older 1998 RR last year from Aweer emarat, they have PITCO service center and this guy plugged X Launch and scan my whole ECU.
Cheers
Chiraag
