ABS Amigo
bink1109
Hey all! Any one know if and where I could find an ABS Amigo here in the UAE? I will order one if I have to, but I would rather run and pick one up here. Thanks!
Bink
For buying new one for discovery will be lot expensive, why not check with used part guys. I knwo one guy guy in sharjah helped me once with used part, you can check with him (050 5866311) dont remember his name, sorry. For buying new one you can check the rates with Gulf star or National auto, their contact has been listed in business listing section here.
I heard a while while back that you can get your ABS modulator repaired too, from where- i dont know but surely give it a try before buying new one. Or else you can also buy refurbished one from ebay.
Thank you! I can do the modular repair, but i am looking for an ABS scanner tool. I am hoping to get some codes for direction. I do not want to throw parts at it that do not need to be changed. Thanks again.
Thats more sensible if you can DIY, have you checked with X-Launch scanner if they have some ABS range. You can buy X for cheap from Alico in Shj industrial area than thru Internet.
  • 4 weeks later...
