Engine Heating in Desert
champlr
Hi Everyone
I am facing problem with the engine after I drive in Desert. After the desert ride, the engine of my car gets really hot. I don't know if that's a big problem? Please tell me what can be the reason of the same and if I need to go the service centre.
Wel there can be many reasons:
Radiator broken: If the radiator of your car is broken then the engine heats up very fast
Low Coolant: If the engine persist low coolants then they are not enough to decrease the temperature in the engine.
Electric Fan cooling: Or may be the electric fan cooling is not working in your car.
Engine overheating is always bad, so you get your car checked in the service centre asap.
  • 3 weeks later...
Thank you. I took it to the center and they changed the radiator. The radiator of my car was broken and they replaced it. So i am not experiencing any heating problem now. :)
