wilson Posted January 20, 2011 Share Posted January 20, 2011 my car is misfire in the 2&3 cylinder and is shaking badly when in idle I changed the spark plugs but i still cant find the fault. pls advice Link to comment Share on other sites More sharing options...
syrino Posted January 21, 2011 Share Posted January 21, 2011 Check the HT lead and then ignition coils. If not then you got to do compression test and see if 2 & 3 cylinder is leaking or some valve is gone. Link to comment Share on other sites More sharing options...
wilson Posted January 31, 2011 Author Share Posted January 31, 2011 syrino, thanx it was the valve issue Link to comment Share on other sites More sharing options...
