overheating
dony
my car was overheating so i figured it out that the engine fan is not working
once replacing it there was a bit of difference but still overheating. what could it be
Have you got the OEM engine fan? Very important part of engine cooling.
Check you AC fan is fine or not? Check your radiator isnt blocked or clogged. Check the thermostat is opening and closing on set temp (80 degree).
