My car is not going above 100 kmph.
davida
there speed of my Lexus is not going above 100. I showed the car to the mechanic and according to him the cruise control is stuck to 100 which is hard for me to understand. As i was not convinced i didnt let him touch the car.
Well you can start with checking if Air filer is cleaned. if that is clean enough then see if the fuel pump is working correctly.
  • 1 year later...
is the check engine light lighted up...? any unusall noise from the engine compartment...? because cruise control turns off when the car is switched off and then back on so it cant be cruise..many times i have seen that peoples cars engine light is also disabled so when selling the car they would get good money for it if you have bought the car used the you should get it checked by a diagnostic machine i m sure you will find something out....
