How do i reset the Rear Caliper Piston inMazda 2?
chinaman
I am not sure, but if C-Clamp isnt working try the Screw-in or channel locks method. I think its screw-in should work in Mazda.
Yes its a screw-in method.
I googled and found this link, which tell you can use two screwdrivers to do this job and not to buy this Laser Brake Caliper Rewind Tool.
http://reviews.halfords.com/4028/694661/reviews.htm
Read the third review
Review 3 for Laser Brake Caliper Rewind Tool
Mazda owners beware,
November 07, 2010
By Mazdaowner
from London
"This is a good solid item and looks to be made well. It comes with a double sided adaptor which means it will fit many makes of car.
The packaging states that it fits Mazda but this is not the case. I found that a pair of screwdrivers crossed over each other did the trick perfectly.
So if you own a Mazda.......Save your money and dont buy this."
Would you recommend this product to a friend? No
Age Group: 45 - 54
Gender: Male
