WHAT BATTERY TO USE ON MAZDA6,2009 2.5L
saalimkola
i checked the user manual the have given the following spec on the battery to be used
12V-48AH/5HR, 55AH/5HR
I FOUND TO HAVE THE FOLLLOWING BATTERY IN MY CAR
80D26 L-MF
Volts 12
Capacity (Amp Hours) 70
CCA (Amps) 630
DO I replace it with the same ? (80D26L-MF)
anyone please help
Yes replace with same what is there in car: 80D26L-MF or any battery that has 70 AMP and can fit in the same battery bay.
Battery main specification is the how many AMP it can deliver. The one you mention in manual is 48 and 55 AMP and one you found in car is 70 AMP, so there is big difference and benefit of doubt goes to the one that is in the car and making run the car for so long. May be manual is showing for some other region or low spec car.
  • 1 month later...
