sunroof needs to be repaired
toheer
You can carefully remove sunroof without removing headliner.
some shops will say you need to remove the whole roof headliner to get sunroof out. but you dont. if you can remove the sliding headliner, then the glass roof. in order to pull out the cables, you need to loosed the sunroof motor so it's not engage with the cables... hope this help..
