noise coming from the engine
mushli
yes of course, i suggest DO NOT DRIVE. Take to good mercedes specialist on recovery.
Sorry but it looks its from crank case, does this noise comes always even on IDLE and get increase when you give gas then crank bearing or something inside engine is chipped or broken.
If same on idle and when you give gas, it could be from tappet cover of adjusting the valve or lifter issue.
