Loud Suspension sound
pawang
I just got my 2009 ML500 from Gargash (pre-owned), from the day that I have the car, it was make a small clunk sound every time i drove over the hump from the front right wheel, but today, after having the car washed at the carwash, the sound got real lod crunching sound from the suspension from both front wheels when going over a hump. What should I do?
For 2009 model, suspension failure or wearing off is quite un explainable.
It sounds like suspension failure from your explanation but also it could be bushings on which suspension sits. Thats why after carwash it got worst. If its only suspension failure or ageing then carwarsh or no carwash makes no difference.
Get the bushes checked and if they look torn, tired or any sign of fatigue then change them first as its cheaper fix before changing the springs or shock absorber
