Wheel Alignment Shop for Pajero 2013
eric73v
Thanks Eric for this info.I also go for offroading with my 2013 pajero and I am also facing the same problem. Will get this fixed at Al Habtoor.
Allo,
I have a new info to share on Wheel alignment and balancing shop.
Al Habtoor gives to Bridgestone ( Al Masood in Abu Dhabi) for all wheel alignment and balancing on all cars which comes to them for service! I dont know where they gives in Dubai.
I will be going there directly to get my car balanced and for alignment checking.
asifmahamood wrote:
> Allo,
> checking.
my car was done in al habtoor garhoud service center. ;-)
I own a Pajero 2012 Model and i have the same problem. My vehicle veers to the right and when i told the Habtoor service guys in sharjah; they replaced all wheels(I have no idea why they did that) and told me it is solved. But still the vehicle moves to right.
Return you vehicle to them brother ;-)
  • 1 month later...
Hi Eric and Asif
Did your wheel got aligned at Al habtoor and how much did they charge you.
I have same problem my car pulling towards right and steering not straight.
Took the car to habtoor service centre at sharjah they change the tie rod and said that alignment machine is not working so i need to get the alignment done else where, took the car to habtoor service centre dubai, they are saying chassis damage i dont know wht to do and whom to believe.
Go to any emarat petrol station and get the alignment done, and then see if car still pulls on one direction. No chasis damage unless serious accident can cause car to pull either ways, it may be easiest way to scare you as they are very busy to spend an hour for too small job of alignment :-)
> Hi Eric and Asif
I took the car to Al Masood (since my tires are Bridgestone and they are the agents in Abu Dhabi) and they have done the alignment and balancing for me. This won't void the warranty of car. It costs AED 200 for Alignment and AED 25 for balancing each tyre, total AED 300.
asifmahamood wrote:
> > Hi Eric and Asif
> where,
> dont
Mind Sharing how you faced this problem of wheel alignment.
