Armada timing belt, when to change?
manju
  • 2 months later...
Armada has got Timing chain you don't have to be concerned about it at all. It will last a lifetime if the engine oil is changed on time.
Lifetime means life of a car or lifetime of engine.....lol.
May car company these days says gear oil is for lifetime, that actually means lifetime of gearbox and this around 100k km.
BTW timing chain has a lifetime too, it should be changed around 150k km. Check the manual, its there.
  • 3 months later...
Till now all I heard is it can last its lifetime. Not even the dealer speaks about timing chain replacement. But there is a periodic inspection to know if there is a premature wear or if the chain is being loose or anything.
