zeuss Posted May 22, 2011 Share Posted May 22, 2011 when the ABS light came up i had to take it to my mechanic who says that the ABS pump has gone bad???? i need a 2nd say on this pls. Link to comment Share on other sites More sharing options...
207_gti Posted May 22, 2011 Share Posted May 22, 2011 did u by any chance recently have your brakes replaced? ADAPT Performance - Power Unleashed SOFTWARE TUNING & PERFORMANCE PARTS www.adaptperformance.com Link to comment Share on other sites More sharing options...
sajanr Posted May 23, 2011 Share Posted May 23, 2011 207_gti is quiet right in doubt. Also check the fuses and relays usually throw these magical lights on. Link to comment Share on other sites More sharing options...
207_gti Posted May 24, 2011 Share Posted May 24, 2011 the reason i ask if you had the brakes replaced is because they may have damaged an ABS sensor in the process ADAPT Performance - Power Unleashed SOFTWARE TUNING & PERFORMANCE PARTS www.adaptperformance.com Link to comment Share on other sites More sharing options...
