Peugeot Scheduled Maintenance Procedures
PeugeotDxb
Inspect Axle joints
Inspect Battery
Inspect Brake hoses & lines
Inspect Brake system
Inspect Chassis lubrication
Inspect Clutch adjustment
Inspect Clutch hydraulic system
Inspect Coolant level, hoses & connections
Inspect Crankcase ventilation system
Inspect Door hinges & locks
Inspect Drive belts
Inspect Drive shafts
Inspect Fuel system
Inspect Horn & exterior lights
Inspect Intake air system
Inspect Parking brake system
Inspect Radiators & air intakes
Inspect Steering system
Inspect Suspension components
Inspect Throttle linkage
Inspect Transmission fluid level
Inspect Windshield wipers & washer
Inspect/Read diagnostic codes
Replace Air filter
Replace Brake fluid
Replace Cabin air filter
Replace Engine oil & filter
Replace Spark plugs
  • 1 month later...
"Inspect Door hinges & locks"
peugeot SHOULD do this, but they DONT. when it comes to these simple things peugeot is exceptionally incompetent. ive have complained about the door allignment on mine many times but they never do anything about it.
peugeots can be great cars but it is because of the absolutely S%#T service that i will never buy another peugeot and advise others not to buy either
ADAPT Performance - Power Unleashed
SOFTWARE TUNING & PERFORMANCE PARTS
www.adaptperformance.com
  • 5 months later...
hi
i read your post and was surprised that you don't get proper service coz i also have a Peugeot 308 full option, 206cc and was having 206 hatchback and 307sw. i get full support from the service dept in rashidiya and in shk zayed road as well.
if you don't mind i would like to know which car do you have and which service dept did you approached and what was the service advisers name, may be i could help you.
pls do reply, my email id is : [email protected]
hi
nah i had the issue almost a year ago. im getting perfect service from shk Z service centre now
how ever, the cervice centre in Al Ain is still as bad as always
hi
good to know that you are getting perfect service now. Mr. Shiva is the workshop manager at shk zayed road and because of him that workshop gives you a perfect service every time.
hi
yup, Mr Shiva is a very good friend of mine. if it wasnt for him, i wouldve sold the car long ago. im glad i still have the car as it has taught me so much. it really allowed me to explore the tuning scene. and ive enjoyed every step of taking it from 175hp and 260Nm to 250hp and 370Nm over the last year
  • Carnity unpinned this topic
