How will i know that the AC gas is less.
berver
How will i know that the AC gas is less i mean there is nooo indication that i have checked the car manual and there was noting no warning sign that can tell this to me.
If the cooling of the AC is getting low that means there is a leak and the leak needs to be fixed so the AC gas needs to be refilled. otherwise there is no need to ever refill AC gas.
like all car parts are serviced and restored in fluids the same goes for AC, yes it dose not come under General Maintenance but the AC maintenance if done once in 50K will save you a lot in long run and you will not have unexpected fail of AC
  • 6 months later...
