Electric Circuit
amid
Hey guys, Just wanted to know how to check the electrical circuit of the car? Thanks in Advance
Cars My passion :mrgreen:  :ugeek:
If you like my above post, please press Like / Thanks on right side to help me increase my rating
To check the electric circuit of the car, one can use either the light test or the typical voltmeter to check whether there is a voltage in the circuit or not.Light test is comparatively not that accurate when using the voltmeter but they are good for quick volt test.
I will try both of them.
Sure. But make sure that if you are using the voltmeter, all the lights and the engine of the car is switched off!
Also, Checking an electric circuit is a process which seems easy but i would prefer that if you have never done the voltmeter test before then take help from the professional. If you leave any of the lights on, then you may get and electric shock. So just keep a note about that.
