Vibration during Idling
pajerodxb
Hi All,
I have a 2005 307cc and for the past few days I am feeling vibrations while idling, when the car moves it gets better. What could be a possible reason for this.
Cheers
Ankesh
I met a friend last night that previously worked in Peugeot Dubai for 15 years as mechanic or probably senior mechanic.
His analysis on the problem of my 307CC 2007 model was awesome.
His name is Sendong and his mobile number is 0503412905
Just mention my name Julius.
Ankesh, If your spark plug, HT lead and coil is good then I think your idle need to be adjusted by adjuster or check the Idle control Valve with voltmeter if its gone bad.
Thanks Vinod.. I got it checked with Swaidan and they said the Engine mounting broke down and have suggested replacement.. but it's very expensive to get it done there. Any suggestions on reliable yet cheaper alternative..
