What should i do when the coolant hose is blown?
abuib
  • 2 months later...
i am told porsche cars are very delicate and the coolant and the engine oil should be used strictly as they are mentioned in the manual :(
mixing coolant and water wasent a good idea :cry:
Use the best available coolant as the temperature s set to rise this year, Check your cooler and radiators for leaks. If you have a leakget it seen to ASAP rather than waiting.
had a friend whose car got blown up unexpectedly and the coolant was drained finally we found out that the coolant hose was blown.
