car halts when overheated
mishhass
the car suddenly halts when it gets overheated a bit,
according to what i have researched i have not read the solution to this problem maybe because they were all European and American websites where cars dont overheat alot
hope u guys can help
Overheating is very common in hot climate like in UAE, in all cars.
Slight negligence in cooling system and booooom.
Check the radiator is first step. Not leaking, not blocked. If yes get it fixed/cleaned.
Check AC fan is working properly.
Radiator has enough coolant and radiator expansion bottle is also filled.
Change the thermostat first when in doubt, as there is no way you can check thermostat inside the car. And changing that is cheaper option.
