what is the next step after fuse check?
deadlydevil
every time i search to find a way to check why the power seats are not working all i find is check fuse check fuse which i did and fuse is good What Next what is the next step.
hahahahahahahaah, check fuse yes but if that's what you have done already then check the buttons if they are working. then check the wiring if any of them is burnt or broken. Electric seats are delicate and has a lot of electric work behind it. If all after this the seats still are not working then let an electrician do is job to fix it.
  • 4 weeks later...
