Door panel checking
rashiddxb
Hi guys,
I would like to dig into one of my door panels and check the speakers and window wiring because the window will not function properly ie, will not go all the way up, plus the speakers are making this distorted noise and i feel it is coming from the same door. How can i look into this?
Do you mean that you want to take out the door panel and check the wiring inside it? I dont know how people gather the guts to do that by themselves ...
The door panel removal needs a little caring but its not impossible nonetheless. You just need to take out the door panel in such a way that it would be easy to reinstall it when you are done. Thats all.
i had to get my windows checked once and i stayed around for the guys to do it in front of me. Seemed to be a little scary process. You need to pull out the control panel of your windows and locks from the door panel with a flat head screw driver and access some screws behind the control panel for the inside handle and screw them out. Gives you access to the wiring and other relevant things on the door.
