Pros and Cons
nackjack
Well about the Pros: Its a Land Cruiser!! I think the ame is enough. It is titled as oen of the best cars for family. Along with that, the car is really safe for kids. Theinterior of the car is also classy. You can always use your ladn cruiser for safari.
Cons:  htink its bit expensive if you compare it with other 4X4 segment cars. I mean you can opt for Prado as well which is cheaper than Landcruiser and alost same features.
  • 5 weeks later...
See, its simple. Its an aamzing car. If you can afford the expense of such a carwhich includes everything: regular servicing, maintenance cost, repair and replacement cost, then this car is really wonderful. But if you think that money can be a bit issue for you, then better dont get it.
