why is my Deville overheating????
you should get following checked first before getting further expenses done
you must
first get the block test done for the presence of hydrocarbons in the cooling system.
Second check if water pump belt tensioner has failed and low coolant level
third will be the internal combustion leaks
these are the major cause for overheat on these engines.
