salmankure Posted July 28, 2011 Share Posted July 28, 2011 i have got new breaks installed and i was told that the center link or tie rod has to be changed as well. all i want is an estimation of the cost please. thanks Link to comment Share on other sites More sharing options...
pancham Posted August 2, 2011 Share Posted August 2, 2011 The center link should be fine unless it is cracked or bent and the inner tie rod ends are replaceable. now for an aprox rates the ends are about 170 - 270 aed, and the labor to replace the ends is about an hour at shop rate. You are also going to need alignment after repair. Could be approximately 800-1000 or so Link to comment Share on other sites More sharing options...
