Electric Cooling fan
kasim
Electric Cooling fan these days is replacing belt driven fans which involves manual mechanism. If you have eletric cooling fan in a car, it helps in reducing the heat in the engine if incase your engine is overheated beause of any leak or if the A/C in the car has been failed.
The manual belt fan consumes lot of horsepower. So the fuel ecnomy goes down andyou can hear the fan noise in the manual belt fan. On the other hand, the electric cooling fan is more powerful and helps in imporving the horse power and fuel economy. You dont generally hear fan noise in the electric cooling fan.
  • 8 months later...
Thanks for your detailed answer. Do you know if all modern cars use electric cooling fans instead of belt driven fans? Is there any other option?
