hilario357 Posted November 26, 2010 Share Posted November 26, 2010 Every morning when starting the car found some water coming at the exhaust pipe and the smell is something like a lacquered paint, smell sweet. Now lately there is an indication of engine problem at the panel board and when pressing the gas pedal sometimes the engine is too slugish to pickup and crawling. I have decided not to drive. Is there any big problem with the engine? The top gasket was previouslyreplaced when I have noticed the oil leakage. Link to comment Share on other sites More sharing options...
Shabir Posted December 2, 2010 Share Posted December 2, 2010 few drops of water at exhaust in morning start up is very healthy sign, other signs is different. Check for head gasket ageing and wear sign. -If oil and water is mixed in engine oil section -if car is overheating -if car losses power noticeable. (either or all) means head gasket need change. Get your engine cylinder compression test from reputed mechanic to be confirmed whether head gasket change is sure or not. Link to comment Share on other sites More sharing options...
