Engine oil- GS350
Jamil Zakaria Bhuiyan
I would like to know is Adnoc Voyager Gold a good engine oil for a 2007 Lexus GS350. The car is of american spec. I have no clue please help me with it. If its not good then please refer any recommendation.
Thanks in advance
Firstly, please check your car owner manual and go with the exactly the same spec as it says be it 0w30 / 5w40 / whatever
If Adnoc Voyager Gold is the same spec as you need, then it's safe to try 100%.
Then start researching why international known big brands of Engine Oil like Mobil 1, Castrol, Liqui Molly etc. are better than local brands so you can decide to shell extra money or not.
its gr engine have tight tolerance in it so gold should work fine unless he fixed some quad turbos and is gonna tear the turmac all over with it....
