lock problem
rinster
when locking the car with the remote, all the doors get locked except the driver door, i got the battery changed but the same problem continues so i have to manually lock it
Check the driver door lock from inside may need some grease or lubrication.
Or else open the door cover and look for anything stuck in between. In last you can change the door lock.
