rishaar Posted April 24, 2011 Share Posted April 24, 2011 All the gears are working fine except Reverse it has a grinding noise when going Reverse please help Link to comment Share on other sites More sharing options...
clive Posted May 8, 2011 Share Posted May 8, 2011 Check if its not the heat shield rubbing down somewhere to drive shaft making grinding noise. If sure its gear, then its good to change the gear oil and filter as a first rule of thumb when in doubt. Link to comment Share on other sites More sharing options...
