verun Posted July 3, 2011 Report Share Posted July 3, 2011 when i felt the loss of power I found the fusible link fried. so replaced with a new one soldering it on and a week later,i had a power failure and the fuse was fried again. I did notice the day before the speedometer was jumping back and forth every once in a while and yes i did get the fuel pump changed so is there any interconnection Link to comment Share on other sites More sharing options...
abaid Posted July 4, 2011 Report Share Posted July 4, 2011 most likely it will be a direct short as in a wire touching the manifold also maybe a shorted to the frame or ignition switch which is mounted on top of the steering column to gain access drop the column to the seat. Link to comment Share on other sites More sharing options...
