Corvette C8 revealed
Corvette C8 was revealed yesterday. I’m surprised it wasn’t posted here yet.
They have dropped the FR setup and went for a MR setup so maybe we’ll see a car that can handle and compete with the likes of Ferrari and Porsche instead of just going fast in a straight line.
Personally I kinda like how it looks. It’s a bastard Ferrari Lamborghini lovechild but there’s still enough Chevy in it for you to tell it’s a Corvette.
  • Totally Agree (+2) 2
Too Ferrari-ish and not enough Corvette Or maybe its just the red paint?
Indeed its super sexy American creation, screaming Chevy everywhere
Image result for corvette c8
Ah looks better in these pics but a lot of Italian influence. Abiut time they ditched engine in the front tranmission in the rear setup.And hope got rid of the rear leaf spring suspension.
2020 CHEVROLET CORVETTE STINGRAY PRELIMARY SPECIFICATIONS
ENGINE
Type:                                             LT2 6.2L V8 VVT with direct injection and Active Fuel Management (cylinder deactivation)
Bore & stroke (in / mm):             4.06 x 3.62 / 103.25 x 92
Block Material:                             A319-T7 cast aluminum with cast-in iron cylinder liners and nodular main bearing caps
Oiling System:                             Dry sump-type (7.5-qt. capacity); includes oil-spray piston cooling
Oil Type:                                        Dexos 2 0W40 synthetic
Cylinder Head Material:             319-T7 cast aluminum
Combustion Chamber volume: 59cc
Compression Ratio:                    11.5:1
Valvetrain:                                     Overhead valve, two valves per cylinder; dual-equal variable valve timing
Valve Size (in / mm):                   2.13 / 54 hollow (intake) & 1.59 / 40.4 sodium filled (exhaust)
Fuel Delivery:                                Direct injection with Active Fuel Management: Max pressure: 2,175 psi (15 Mpa / 150 bar)
Firing Order:                                  1-8-7-2-6-5-4-3 (all cylinders); 1-7-6-4 (with deactivation)
Throttle body:                                87mm single bore (electronic)
ECU:                                                GM E99 (32-bit processing)
Horsepower (hp / kW @ rpm):   SAE-certified to 495 / 369 @ 6450 rpm (with performance exhaust)
Torque (lb.-ft./ Nm @ rpm):        SAE-certified to 470 / 637 @ 5150 rpm (with performance exhaust)
TRANSMISSION & AXLE
Type:                                              M1L 8-speed dual clutch (DCT)
CHASSIS & SUSPENSION
Front Suspension:                       Short/long arm (SLA) double wishbone, forged aluminum upper and cast aluminum L-shape lower control arms; monotube shock absorbers (46mm /); Magnetic Selective Ride Control 4.0 available on Z51. Adjustable front lift with memory is available
Rear Suspension:                        Short/long arm (SLA) double wishbone, forged aluminum upper and cast aluminum L-shape lower control arms; direct-acting stabilizer bar; monotube shock absorbers (46mm); Magnetic Selective Ride Control 4.0 available with Z51
Steering Type:                              Bosch/ZF variable-ratio rack-and-pinion with electric power assist; includes Active Steer Stops with available Magnetic Ride Control 4.0
Steering ratio:                               15.7:1
Turning Circle (ft. / m):               11.6 m (std.) , 11.1 m (with FE4 Magnetic Ride Control)
Brake Type:                                   Front and rear E-boost-assisted discs with Brembo four-piston/two-piece front calipers and four-piston/monobloc rear calipers
With Z51 – Front and rear E-boost-assisted discs with Brembo four-piston monobloc caliper at front and rear
Brake Rotor Size (in / mm):       Front: 12.6 x 1.18 (321 x 30) , Front: 13.3 x 1.18 (345 x 30) – with Z51, Rear: 13.6 x 1.02 (339 x 26), Rear: 13.8 x 1.06 (350 x 27) – with Z5
Wheel Size:                                   Front: 19-inch x 8.5-inch (w/5 x 120mm bolt pattern) , Rear: 20-inch x 11-inch (w/5 x 120mm bolt pattern)
Tire Type and Size:                      Stingray: Michelin Pilot Sport ALS, Stingray with Z51: Michelin Pilot Sport 4S, Front: 245/35ZR19, Rear: 305/30ZR20
^Do not use summer-only tires in winter conditions, as it would adversely affect vehicle safety, performance and durability. Use only GM-approved tire and wheel combinations. Unapproved combinations my change the vehicle’s performance characteristics. For important tire and wheel information, go to: my.chevrolet.com/learn/tires/ or see your dealer.
EXTERIOR DIMENSIONS
Wheelbase  (in. / mm):                 107.2 / 2722
Overall Length  (in. / mm):           182.3/ 4630
Overall Width  (in. / mm):             76.1 / 1934
Overall Height  (in. / mm):            48.6 / 1234
Track (in. / mm):                           (front) 64.9 / 1648 , (rear) 62.4 / 1586
INTERIOR DIMENSIONS
Headroom (in. / mm):                   37.9 / 962
Legroom (in. / mm):                      42.8 / 1086
Shoulder Room (in. / mm):          54.4 / 1381
Hip Room (in. / mm):                    52.0 / 1321
WEIGHTS & CAPACITIES
Dry Weight  (lb. / kg):                     3366 / 1530
Cargo Volume  (cu. ft. / L)^:          12.6 / 356.8
^Cargo and load capacity limited by weight and distribution.
Edited by Javier M
  • WOW (+2) 1
They did, I am sure they had to, there was no space with the 6.2 L engine at the back.
Edited by Javier M
  • 2 weeks later...
Well now I'm starting to like it, that interior is dope! And all for the price of a lux SUV ! Really is a supercar at muscle car price.
Edited by desertdude
