Vibration on High Speed
Sidshk
This is or someone else who is not yet member.
He drives Paj 2010  3.5
Now below are some of issue he faces
There is Vibration from back of the  car between 80-100 Kms and there is some sort of propeller sound
Post 100 to 120 There is no vibration, after 125 and above there is vibration in the steering wheel
What can be possible cause ?
Does the sound increase with the speed or does it disappear? If it increases it could be a case of failing bearings or noise from tyre. Swap the tyres with the front and see if the sound from the rear reduces.
both vibration and Noise dies after 100 Kms
5 minutes ago, Srikumar said:
Then check the condition of the tyres. Might have developed some uneven surface
Tyre are new 2019 - Only Six months
Some tyres are bad right from the start. Have them checked out at a proper tyre shop.
tires are fine , He has checked it from Bridgestone store
Sounds like a wheel balancing issue
Possibly amplified by some worn bushing or bearing
Exactly, This is wat we found out last night there is some issue with one or multiple Bushes but the problem is we cannot identify which one.
Lift the car up. then first hold the tyre at the 3 and 6 o'clock positions and jiggle it then the 12 and 6 and do the same 5o check for play. Then Take a tie rod and jam in between all the bushes and give it push and pull and see which bush has excessive play or is visibly cracked or squished
