Kwarkwer Posted May 2, 2021 Share Posted May 2, 2021 I just noticed this on my Lancer GT 2015. Once I am backing up out of the parking, I can hear a loud popping noise while braking on the front end. Any suggestions what to check? I haf already changed the brake seals and lubricated things that needs to be, but still having this noise. Should i check other things (suspension, bushings)? Tie rod end and stab link are new also Link to comment Share on other sites More sharing options...
Frederic Posted May 2, 2021 Share Posted May 2, 2021 1 hour ago, Kwarkwer said: I just noticed this on my Lancer GT 2015. Once I am backing up out of the parking, I can hear a loud popping noise while braking on the front end. Any suggestions what to check? I haf already changed the brake seals and lubricated things that needs to be, but still having this noise. Should i check other things (suspension, bushings)? Tie rod end and stab link are new also I would advise to get the engine mounts and suspension checked. Does it only appear when braking while reversing ? And are you turning the steering wheel when this occurs ? "Go as far as you can see; once you get there, you'll be able to see further." Link to comment Share on other sites More sharing options...
Kwarkwer Posted May 6, 2021 Author Share Posted May 6, 2021 Yes it only appears everytime i back up and apply the brakes. There are times also that it pops when i turn the steering wheel. Link to comment Share on other sites More sharing options...
