Regarding airbag disable on Y62
Daniel Yang
Hi guys,Anyone can teach me how to disable the airbags and abs on y62,just remove the fuse from engine bay everytime before heading to sand?
Hey @shu yangthis is how you disable ABS every time you go on the sand, and you need to restart the engine whenever you plug it out or in
@RooRzOn Thanks mate, for ABS should we do the same plug thing, is that necessary to disable ABS also in sand drive?
What I've shared with you is the ABS killing method and its important to fully disable ABS while on sand because this system senses slippery tires and disable the breaks to control the slipping. This is very bad on sand because sand is always slippery and you will need your breaks working 100% to help you stop before a cliff or any other dangerous situation
For me I started disabling it on Fewbie level where the pace is faster and you will be using the breaks more harshly
@RooRzOnhi bro thanks for explain for ABS killing, but my original question is how to disable the AIRBAG😜
  • 2 weeks later...
Mario Cornejo
@shu yang - most likely you will have to disconnect the fuse for SRS System (Supplemental Restraint System).  That's what I do in my Y61, just be careful to turn off the engine and remove the car key before removing and before putting back the fuse.
Hope this helps.
Edited by Mario Cornejo
