Radio channel setup Crony Dt-8188
Hitham mohamed
5 hours ago, Hitham mohamed said:
anyone has the channel setup proicess  for radio Crony DT-8188
@Islam Soliman has this radio if I’m not mistaken.
Here are step by step instructions for setting up Crony DT-8188.
  1. Power on
  2. Choose A (upper) as main
  3. Press menu
  4. Scroll down till u get FREQ
  5. press ok
  6. Press exit
  7. Manually enter the frequency you want
  8. Press menu
  9. Scroll down to MEM-CH and press ok
  10. Choose which chancel u want to save this frequency to
  11. Press ok
  12. Press exit
  13. Press menu
  14. Press ok
  15. Scroll to CHFREQ
  16. press exit
Your new frequency is saved to the channel you selected, you can lower off and on and check now
Now you need to repeat same steps after switching to B as main
let me know if you need any help there @Hitham mohamed
  • Well Done (+2) 2
  1. Power on
  3. Press menu
  5. press ok
  6. Press exit
  8. Press menu
  11. Press ok
  12. Press exit
  13. Press menu
  14. Press ok
  16. press exit
Thanks i will try and let you know if i need help.
33 minutes ago, Hitham mohamed said:
still did not work to set each channel. quite complicated .
worst case just keep a small overview of our frequencies in your car, and just type in the frequency manually at the morning of the drive:
this is what i did last time .
