the radiator water overflowed
Its time to put that old explorer to rest mate. lol.
Radiator water overflowed from expansion bottle is quite normal as when car overheat a bit water expands and rushes out thru the expansion bottle.
If you mean actually from radiator then that may be radiator cap was loose as it suppose to with hold certain pressure to be build up in radiator for cooling, if its loose it will leak water and car get overheat.
If cap was tight and still water came out from radiator, then that mean radiator core busted and you need to either change the whole radiator or at least its cores.
