My car shuts off after 5 min of starting Why?
shakeer
  • 1 year later...
It mean your car needs service normally, if is not starting it needs service, that mild indicates there is some technical issue.If you stop your car just after you have started it the choke is still set up. to get over this, push the your pedal to the ground and turn the key, do not let go of the key until it has started.
  • 1 month later...
