Need help identifiying hose
DellYan
Hi Guys,
A hose started leaking in my Pajero causing it to overheat, I located the leak following the rust infested coolant, so will also be replacing the radiator and hoses now
If someone can tell me which hose this is since I plan to buy all the parts needed:
HighlightedGreenhose.jpg.2b29e3365eb7380f54b17cf9a687bb2f.jpgHighlightedGreenhose2.jpg.b629579b60c44d7418e0885d3fe9dd90.jpg
Many many Thanks~
Appreciate some more details like year model, engine trim etc.
Plus slightly zoomed out pic to see if hose originate from engine oil pan or gearbox oil pan.
In my 1999 Pajero, I have engine oil cooler and very similar hose is carrying engine oil from sump to cooler and return.
If you can run your VIN number in megazip, then you can check each part with diagram and code number to order from habtoor.
Hi Gaurav 😀
Just did a quick search using the website you mentioned and I found the hose I was looking for 😁
It's the hose for the heater core
Really Appreciate the info
