CRV temp warning?????
zubs
Honda CRV 2007 have some water / coolant leaking issue on drive way (overnight). Its very less but i cant figure out from where.
Is CRV have water loss icon display in dash, in case when i forget to check the water in spare bottle. Will get this fix in about month when i have some free time, till then i need to put this on back of my mind.
I dont think it has, as mine doesnt. But may be newer model has. Check half key light check when all lights are lit for 5 seconds as a test, see if you can see some thermo icon with wavvy water level sign. Usually thats the low water gauge, i used to have in my Volkswagen in past.
