car is making noise
miyaa
my car was making noise for quite some time,showed to one of my friends who has a bit of knowledge about cars said it could be wheel bearing but if it could be the case then it would have worn out by now.
I got the tires rotation this morning which made the situation a bit better
when taking left turns i can hear the CV joint ticking very lightly which i can hear only when taking extreme left so then I've had differential fluid changed.the car is still making noise even after i have done these jobs
thanks for the help in advance
  • 2 weeks later...
If you have doubt for wheel bearing, lift the car on scissor jack where all 4 whel stays in air and then hold the tire from half way, and shake it hard. If feel little or more play its confirmed problem of wheel bearing. Changing or rotating tyre wont help. Change the bearing and balance the tyre and align it well.
