audidub Posted February 9, 2012 Report Share Posted February 9, 2012 Hi guys Is it technically possible to fit a turbo charger on on naturally aspirated 2007 Audi A3 with a 2.0 ltrs engine ? Other than the intercooler and ECM is there anything ? good work for this nice forum Link to comment Share on other sites More sharing options...
dilshad Posted February 10, 2012 Report Share Posted February 10, 2012 2.0 L I4 FSI and 2.0L 4cyl Turbo 6A shares absolutely same platform so you can actually installed Turbo without any big trouble, just need to double check the spacing issue and other wiring flow pattern. Link to comment Share on other sites More sharing options...
audidub Posted February 10, 2012 Author Report Share Posted February 10, 2012 What about the pistons ? Are they the same ? Can they withstand higher stresses and temperatures ?? Link to comment Share on other sites More sharing options...
dilshad Posted February 10, 2012 Report Share Posted February 10, 2012 Which engine you got: AXW / BLR / BLX / BLY / BVY / BVX / BVZ Link to comment Share on other sites More sharing options...
audidub Posted February 12, 2012 Author Report Share Posted February 12, 2012 Hi Dilshad , It is a BVZ capacity 2000 CC FSI Link to comment Share on other sites More sharing options...
dilshad Posted February 14, 2012 Report Share Posted February 14, 2012 Soryy for late reply, and another sorry that BVZ you cant turbo boost as it has different platform and that's why i assume it must be using different internal components for turbo alternates. If you had BVY then you could have tried within safe bracket. Link to comment Share on other sites More sharing options...
audidub Posted February 14, 2012 Author Report Share Posted February 14, 2012 This what i was expecting Thanks for the info Link to comment Share on other sites More sharing options...
dilshad Posted February 15, 2012 Report Share Posted February 15, 2012 If you are really keen plonk the other engine block and then turbo charge it. Slightly more pricey but lesser than swapping engine. You may find one in used accidental half cut cars. Link to comment Share on other sites More sharing options...
