Where is the fuel pump located in Honda Accord?
musit
  • 9 months later...
dasautoservices
Fuel pump is located at the rear fuel tank, you can open the rear boot there is a small cover, when you remove cover you can see 6, 10mm nuts, remove and replace
  • 7 months later...
  • 4 weeks later...
transporter2222
The fuel pump is located in the boot/ trunk under the cover. And its life depends on kms like around 1.5 lac kms are enough to change the fuel pump.
  • 3 weeks later...
  • 3 weeks later...
