my bimmer does not start
johnbimmer
last night was the last time i saw my 323i alive, i have been trying to start my car since morning. i got it washed last evening in emarat so could it be because of that..
help me please
Hi John
start up problem could be from following things ONLY:
Faulty / dead / weak battery
Dead Starter (self)
Fuel supply choked
Spark plug isnt firing
Elctrical malfunctioning from sensor / fuses / relay.
Please tell me that is your car cranking but not starting?
Or car self making click click but not cranking?
Or its completely dead and no crank and no click click when you start?
It has no crank and no click click when i start the car. Battery seems fine as all lights are on and also tried jump starting the car but still no life.
My neighbour doubts on fuel supply or some electrical sensor to get sucked in water during the wash.
99% its a dead self (starter motor).
But before doing expensive job, check free things first. Check all fuses and relays and if its fine then its Self.
(CKPS) Crank position sensor or (CMPS) Cam shaft position sensor has all duly protected with road water and mud and have different symptom in non starting the car. They dont die all of sudden w/o showing any signs.
  • 1 month later...
help me please
hi brother.
dud you solve your problem????? if then please reply the reason...thanks
  • 2 months later...
