AC not cooling enough
khandelwal
Salaam friends, I am noticing a huge difference in the AC cooling in my patriot and am worried that it might turn into a big problem. Dont know what is causing the problem. The air coming out of the AC is still cool but very lightly. What can be causing this? An idea of the problem would help me understand the dealership's opinion as well. Thanks everyone.
The refrigerant/freon levels must be low, can be a leak... have that checked, or the ac compressor might be broken or not working properly if the belt on it is not secured enough. Just a couple of common problems from the top of my head.
Seems to be no refrigerant in the AC system like rao rightly pointed out. Dont worry about these small things, just have the Ac checked? if its the compressor causing the problems then they will replace your compressor. these things happen a lot here in the UAE, climate conditions being one of the most common reasons.
  • 1 month later...
thanks guys eventually the guys at Trading Enterprises had to change the compressor so you two were right there. It took them a couple of days but the AC seems to be working normally. Really glad I was mentally prepared for all that thanks to you two :)
