CAR IS SHAKING AND LOOSING POWER
xener
WHEN STARTING THE CAR IS STARTED VIBRATING VERY FAST AND SWITCHED OFF. GOT THE BATTERY AND ALTERNATOR CHECKED AND EVERYTHING WAS WORKING PERFECTLY.
Check the air flow meter is not unplugged or loose. If its fitted properrly then more likely either AFM needs a change (expensive) as its not working or engine need tune up (cheaper).
