why the red brake lights dont work
numerouno
the red brake lights work at times and dont work at times. what is this and why dose this happen i even checked the fuses all were doing good i mean working then why? its expensive changing them the lights i mean so i want to avoid the expense is there other way?
if they are not working then it can be hazardous to the other when you are driving. first check the wiring if your car is not too old then check the fuse.
