how do i replace the pulley on Infinity
get all the belts Disconnected and remove the pulley central bolt
you need an impact wrench or appropriate holding tools for the pulley that will be available in sharjah
the pulley will be accessed form under the car
generally the bolt size has to be a 24 mm but different engine varies, from 19 to 27mm it should be mentioned in the manual
