gasoline door stuck
  • 3 weeks later...
My friend if you try to open it your self using anything you may end up having scratches or dents best is use load of WD40 on the latch of the door from out and leave it for half n hour
Ask some one to press the button of opening the gas door and with a minus screwdriver with some plastic on the sharp edges try to pull it off.
If this fails i suggest take your car to a good mechanic it maybe a fuse problem too.
