accessory socket not working
dreamer
Hmmm. I see. I faced this problem once. My friend who has his own garage told me to do a simple circuit test. This test is basically to check the fuse in any part of the car
Sure. Take a test light and attach the clip end of the same outside the socket frame. The other longer point end of the tester and move it to the socket inside till it touches the back of the socket properly. If the test light blows, it means the fuse is perfect. If the tester doesn't lights up, it means you need to change the fuse and it will work again.
